Low drag - High speed
- Joined
- Oct 24, 2003
- Messages
- 201
- Location
- Okla-Frikkin'-Homa
- Corvette
- 1995 and 1984 Red Coupes and grey 2007 GMC Sierra
Another good reason to keep her topped up is fuel weight. The pressure at the bottom of the tank is higher when a few more gallons are sitting on top and it helps push the fuel through the pump, assisting the turbine and reducing wear on the pump. Less important than the cooling, but another small part of pump life and engine efficiency.
As for wires inside the tank ... as long as the connectors are tight there is no fire danger, even when the level is low. Electricity is not the danger, but rather the spark it generates when loose parts brush together. No spark ... no explosion. And previous posts are correct about oxygen. Gasoline will only burn on the surface, which is why it's turned into a vapor for internal-combustion engines. Fine droplets burn very well, but standing liquid will nly burn on the top and will not explode. If other factors are added, like a bomb, a collision that scatters it in the air, or a tracer bullet that causes it to expand and then lights it, you have an explosion ... but not just by itself. And don't forget the spark ......
