Marv02
It sorta runs.
1986 Coupe
After putting the New 383 in.
It's poping fuel pump fuses.
I can jump ADLC to the G port straight to the battery with a new fuse works fine runs Fuel pump.
Remove the Jumper wire using just the Key I have power to the fuel pump but after starting the motor it a it blow the fuse I checked the wireing cant find any thing wrong with it use a meter good conections good voltage.
Replaced the Relay it has a new Oil pressuer switch.
I have upped the fuel pressure up to 58.5 with a walbor fuel pump if this has any thing to do with it blowing fuses I dont Know.
The pump worked fine before the motot swap.
I out of Ideas.
HELP
1986 Coupe
I out of Ideas.
HELP
