E
ErnieN85
Ken, how fast was the car moveing?
you need to be going 40mph to get enough air flow from motion. if it's stop & go and your going over 2000rpm or so
the fans even if they are on won't pull enough air unless there is a sealing between the radiator and the cooler. it looks to me like there is quite a bit of room there for the air to just go around the cooler. now that said I'm using an adapter with a builtin thermostat and when I put it on the passages looked quite small to me. so probably that's not your problem. a fan is used by one of the cooler makers mounted right on the unit. if your in stop & go and reving it between stoplights that migh be the only cure.
