R
RedHookGal
Somebody tell me if this makes any sense:
Car began to run really crappy a few days ago, and the "check engine" light popped on. So I looked around here to figure out how to retrieve the code, and on Sunday night went in and got a code 44. Read up on that, then spent some time tracing down vacuum lines, and doing other stuff that various people recommended here. Also ordered a new oxy sensor, since I figure that it has been sitting a lot in the last few years, and that knowing I have clean sensors wouldn't hurt.
Soooo, today I go in and want to clear the memory of the codes. I disconnected the negative and let it sit for about 5 minutes. Went back in, and code was cleared. But when I went to turn it over to move the car all the way back into the garage, it let out a really loud GACCCCKAAAA-GACCCCKKAAA-GACCCCKKAAA, and did not start. I shut it down, let it sit, and then hit it again; same noise. It sounds like the starter is gone.
Does this make sense? Could I have killed the starter by removing the negative battery line?
Kathy
Kathy
