K
kirbys57
ECM ? installed ZZ4 motor w/carb. will car start,run if ECM is unpluged ?
No.
It needs the ECM's control over ignition to run. You can change to a non-computer distributor, but you're still going to have trouble with the lack of an RPM signal causing the ECM to cut off the fuel pump after 2 sec.
