knock sensor weirdness?????
  • Thread starter Thread starter bradslt5
B
bradslt5
i have this little habit of leaving my scan tool on while driving on the lonely hiways ups hear .first off car throws not codes . i am driving and look down and its showing 3,4 deg of knock retard while driving on perfectly flat road . it will go 1-4,3,2 ..on a trip to ridgecrest from lone pinewhich is down hill it hit the knock sensor 187 times on the way back -up hill it hit 35 times . wtf . could be going on iknow its got good gas . i even put in 100 oct out of my own 300 gallon container before i left last time .. my blk zr1 might through the knock 10-15 times on a round trip. the car has new plugs and wires . my scann tool has brand new batts. any ideas ???????????????????
HI there,
It is possible the piezo resistor is loose inside the sensor.
Frequency is really the telling sign on this, because the sensor picks up vibration, not just engine knock.
So, that being said, you may have a bad sensor.
The key would be to monitor frequency from left to right to determine what is going on.
Allthebest, c4c5
you mean i have an italian loose in my sensor .jk thanx i have a new one that i bought a couple of yrs ago . they are the same for all lt-5s? thanx again
thanx for the heads up . off the subject . how do you get a top off that has a broken head . all thats holding it is the threaded part of the bolt .i just found it .joy of buying a car.hidden jewels dont yya love it .
