I just finished installing a XE 262, 1.6 roller rockers, Vortec heads, performer intake, TCI 2k converter & hedman headers on my L48. I am still in the process of getting everything dialed in but seat of the pants feel is promising. Just a little lumpier idle than I wanted but it is probobly from the 110 deg LSA. Liveable though. I read a test on a motor with the exact same combination as mine except on a 305, not a 350 & the 305 made 325hp. So I am hoping for around 340 or so. The Vortec heads are supposed to be one of the best heads you can run for a mild street motor, & they are priced right. The only hitch about the Vortecs is they will not handle alot of valve lift in the stock configuration. Summit sells the upgraded heads with machined guides, dual springs, & set up for screw in studs for about 360 ea. They are good for .550 lift.
