Jack Cooper 350
;helpI have removed the left h/light from my 1992LT1, as it was not lifting or retracting properly. The GM Service Manual doesn't go as far as the motor/gear-set tear-down process, which I have done, and found the 3 Delrin bushings were totally zapped. Looking at the Mid-America/Ecklers catalogs (etc.) it seems that this is a common problem. Oh - and Richard Newton's great '101 Projects' book! I am currently waiting for the spare parts to arrive and am starting to fret about re-assembling the headlight: how do I ensure the motor runs to the correct 'fully up/fully down' positions, and then stops? I have decided to build a test-frame to mount the unit and test/adjust it prior to refitting to the C4 hood. Grateful any inputs from you guys if you have done this - I'd appreciate any particular snags to watch out for. (Obviously, I intend to reassemble in the exact reverse order of removal, in terms of shims/positioning etc.)
Tks in anticipation - J.C.
