Hello everyone,
a couple of Fridays ago, at the end of a very long and day, the vette stalled a couple of times while driving, and to re-start, I had to press on the gas pedal hard, and once it started, it would make a huge cloud od smok. I was confused about Gail's behaviour.
Something told me to start with the manifold differential pressure sensor, which in hopes of simplifying things, I am just going to call a MAP sensor. :ugh
Anyway, when I follow the firt step in the trouble shooting charts for bad MAP sensor, I got a voltage equivalent to nearly 5,000 feet of altitude, and I thought, "oh well, it looks like it is reading right, buti'll go ahead and apply some vacuum and see if it changes like it should, just like it says on the next step.....if I can only get it to move with vacuum applied. That's right folks, it was stuck at the same reading even with 20 inches of vacuum applied.
ad
So then, I tried to follow the troubleshooting chart, and it kept pointing towards a bad sensor, but when I hooked-up the new sensor, it also did read the same voltage. When I followed the decision branch to the right, it points to a bad ECM; however, it says to, 'check for terminal 1 at ECM terminal to see if it is grounded, and if it is not grounded, then replace ECM'. I am paraphrasing here, since I do not have the manual with me right now.
In the hopes that someone could save me another weekend of troubleshooting, I was hoping that someone could recommend a short cut, and help me avoid purchasing a new ECM before checking a few other checks. I believe that ECM are not returnable, so if I buy one, I need to be able to be prett certain that it is an ECM problem
Inputs requested.
adSo then, I tried to follow the troubleshooting chart, and it kept pointing towards a bad sensor, but when I hooked-up the new sensor, it also did read the same voltage. When I followed the decision branch to the right, it points to a bad ECM; however, it says to, 'check for terminal 1 at ECM terminal to see if it is grounded, and if it is not grounded, then replace ECM'. I am paraphrasing here, since I do not have the manual with me right now.
Inputs requested.
