S
sd pacecar
I have read alot of info/opinions on the various aftermarket heads available. It seems all of them out perform the stock heads. I would like to know if anyone has set up a factory head with a port/polish job, pocket porting or any other trick to improve the performance of the factory head.
The reason I ask is I would like to keep the engine original in my Pace Car. I have heard varing opinions on aftermarket intake manifolds v stock. Some say the performance gain is not very much. I would like to keep the factory intake, along with the heads. With that in mind, what kind of power gains could I expect from a totally worked set of L82 heads? And would it be posible to Extrude Hone the factory intake? It is aluminum.
I have the 700r4 and 3:55 gear.
