L88 Hood On Order!
  • Thread starter Thread starter Hijinx
Got the latch problem fixed. Looks like the only areas that will require some fitting, is the nose and the rear tips. Both are too low. Can someone inform me how this will work. The sides, and front corners are right on. However the nose is low and creates a gap, and the rear tips are low. It looks to me like this would require some glass work to fix. Any thoughts?
Jack the whole thing up with shims under the hinge and latch points then sand down the high spots?
Good tip, I agree.
