L
livinez
Well the 85 has been torn down since turkey day and may other life things has slowed work on it.
So far the engine is out and block is getting cleaned, checked and new freeeze plugs and cam bearings. Block is in great shape with crosshatch still visible in cylinders with miniminal wear. Heads were just as good.
So lapping in valves and reuseing springs rockers and pushrods.
Will redo cross hatch to break in new rings.
All new bearings and reuse orginal pistons and rods.
Cant find stock specs on the cam which I'd like to replace with one of Summits cam and lift kits.
Was advised elsewhere that Summits 1100 cam kit would be fine for stock motor.
But without the specs to make educated decision on cam will probably reuse old one and its lifters as I kept them in order.
Only mod so far is gutting cat (no smog checks here!), nixing air pump and cutting off air tubes on exhaust manifolds.
Will probably do some of the "free" mods mentioned, but some dont suit living in a rainy state.
Will send pictures as soon as I can find problem with this computer or IP that prevents mme from sending them.
