- Moderator
- #1
KANE
Moderator
- Joined
- Mar 2, 2002
- Messages
- 3,244
- Location
- KY
- Corvette
- Dark Blue 1982 Trans Am(s): Polo Green 1995 MN6
Yesterday was a great day!
I set the timing for 6 degrees per GM for speed-density TPI. Then I set the minimum airflow (per GM procedure) followed by the idle.
Now, GM calls for a minimum of 450-500RPM in drive for a stock TPI, but between the components (runners, chip, injectors, L82 factory cam & heads), I have her set at 600RPM. 500RPM was just too low for my set-up and she'd stumble and stall. 600RPM was the lowest she'd run comforatbly.
Then again, in my experience, 450-500 is just way too low. The previous TPI system I built was on an LM1 based 350. Same scenario though- when I tried to set the base to 500RPM it stumbled and died. Seems my combinations don't like a 500RPM minimum idle. Maybe the L98 does better at 500RPM with the more restrictive intake snorkeling and oppresive exhaust system- most likely having to do with back pressure & scavenging. It has never worked on my TPI motors. I guess it doesn't matter because they don't throw codes at an idle between 600-750RPM and they NEVER stall.
She sounds great overall. The throttle flows freely off idle and she roars through her RPM band. She really wants to run and she does well getting there. I'll have to add some octane booster when I finally get her on the street to help burn out the old gas. She really looks good with the polished intake. I really feel like the little details have made this just that much more successful in terms of the swap.
I really enjoy TPI over carbs. That may be blashemy amongst most C3 owners- but it is sooooo much easier to tune and more reliable (if done right). It cleans up the engine bay nicely. Just my $.02 though.
I'm ordering new seats this week. With any luck... she'll be on the road by the end of the month- I've still got to register her (bad owner!).
:cool
:cool
