bobmanx
- Joined
- Dec 29, 2002
- Messages
- 169
- Location
- Southern Calif.
- Corvette
- 1967 White Convert. 327/350hp, 4 spd, with A/C
C2 Leaking Heater Core, Opinions needed, Thanks!
Well, it appears from all the checking, that the heater core is leaking and being forced through the heater/defroster/ A/C ducting to both sides of the Corvette floor. Its a C2 convertible, 327/350 hp, 4 spd, WITH A/C. What is the recommended way to plug, bypass, reroute, modify the heater hoses to make it driveable while I get the parts and the enthusiasm to replace the heater core.
Remember there are a few more parts to remove since the car came with A/C and some suppliers of the core seem a little less than knowledgable as to correct hoses and core for a A/C equipped 67. Which supplier and core is correct, some claim that the hoses are two different sizes, and the info gets worse from there. It appears to be 5/8 in on the top inlet under the hood and there is a vacuum operated valve on the lower pipe so who is a expert, as to whats correct and whats the proper way to patch it till I can get the "CORRECT PARTS"?
Thanks for all help and opinions.
Bob
P.S. Vigman are you still alive and how's your project?
Bob
