leaking top blues
  • Thread starter Thread starter tdr1919
T
tdr1919
On my 86 coupe I get leaks at both front, top corners where the side windows meet the winshield and the top. I replaced the winshield weatherstrip, and a new refurbished acrylic top. The window(s) appear to fit snugly and up against the top & winshield weatherstripping.
Any ideas?
Tom
Do you mean you replaced the header weatherstrip at windshield or the actual windshield seal that you need to remove the glass for?
I recall reading a thread on a vette board where it was leaking at the actual windshield seal.(behind the glass)
I had a similar problem with my Pontiac. I had to spray with water hose to find the leak. It was easily repaired. Most auto stores sell a sealer that is very viscous.
It flows into the gap like water does but then hardens and seals it pretty much permanently. Did mine over 5 years ago :cool
I actually replaced the windshied but it is not leaking from the winshield it actually drips down from the top corners, and leaks around the side window glass.
Is it a Thompson Astro Top? I have some problems with the quality of their work. Maybe thats it?
Hmmm...and it has this corner metal water deflector? (part #38 on the chart) Maybe water is leaking through a gap where it attaches to the panel?
