joli
I need to ask if there is anything outside of the obvious with regards to a pretty severe transmission fluid leak coming from the pan. I just had the transmission rebuilt it is a 700R4 in a 82. I keep bringing it back for minor leakas and they clean it up with brake fluid, wipe it off, run the car, then identify where the leak is coming from, tighten up the bolts a bit, let it sit while running, check for leaks, seems good and off I go. I then take the car for a trip to the beach which is 90 miles one way and the car runs fantastic. I get home then park her in the garage and when I check it in the morning my drip pan (which is 2'X3') is full of transmission fluid. It took an entire roll of paper towels to pick it all up if that gives you any ideas. I am now pretty upset so I jack up the car and go under myself to check things out, I do not see much other than the mess from the leak, I clean it up and then take the time to check and see if the bolts are tight, and find out that they are not. Surprisingly I am able to tighten them up a bit, almost all of them with the exception of one, the one that has a bracket attached to it spins it the breeze so I'm assuming that it is either broken and or stripped which may be the problem. Would one bolt on the pan not doing its job account for that much of a leak? I've also been told that it the bolts are over tightened it will warp the pan and if the pan is warped it will continue to leak no matter how tight you bolt it in.
