How common is it for newly-installed o-rings to leak vacuum a little? Once again, I have the car all together and was testing it for vac leaks. If I spray carb cleaner onto the manifold by each injector (so far, I'm 6 for 6), the engine revs higher.
These are all brand-new rings, lubed with a small amount of clean motor oil before installation. The fuel rail is tight against the manifold. The injectors will rotate when pushed, but not easily.
What's going on?
Thanks.
[RICHR]
What's going on?
Thanks.
[RICHR]
