lean o2 what are the causes?????
  • Thread starter Thread starter bradslt5
B
bradslt5
got a lean o2 code on the left side , what are the causes.? blk learns are 120-123 l 132-137r when cruizin @70-75
Hey brother, Hows it going. Well from what I gather some of the causes are, clogged injectors, low fule pressure ect. Here is a link that covers diegnosing lean o2 sensor's. Its pretty in depth http://www.asashop.org/autoinc/MARCH/TECH2TCH.HTM . It might help. But if all else fails just call the wizard Cory.
thanx pards, are you watching the masters .those greens gotta be painted marble. thanx for the links . i still havent upacked since we moved i know deb put the fsm somewhere . i think she is playing one of her little jokes on me . gives me a reason to smile . your aces , coreys so busy i hate to bother him
Restricted injectors are one.
Fuel pressure you can discount as fuel pressure affects the entire engine and you have only the left side running lean.
Vacuum leaks are another reason for lean exhaust.
But, rather than guessing a bunch of stuff, the best bet for you is to pull the actual codes, then diagnose and repair the engine per the FSM.
hib thanx for the info, its showing a lean left 02 code . i cant find my fsm. due to move wife pscked everything ,but unfortunatly she and my 2 unborn twins passed recently .but i cant find it could you give me a couple of things to ck , than for youer help
I'm not very good at reading some of the texting shorthand you use, but if you're saying that your Wife and your two unborns died, I am so very sorry for your tragic loss.
Bring your car down to L.A. and I'll be glad to take a look at it at my shop and try to help with some diagnosis.
hib thanx , ya kinda lost without her , we had just moved into our new house and . she allways liked to play tricks on me like hiding the fsmanual.. so darned busy with work . having fun with cars on the back burner for a bit . but i'll see if i can brealk away. not code i forget to wear glasses:D
