M
mike
Couple of questions on a 61. I recently purchased a 61 driver that sets about 3/4 inch lower on the drivers side. It looked like I had a weak rear leaf so I installed a new set. No Luck Here! Car sill set with lean. I then let enough air out of the passenger side right tire to level the front. This also brought the back into an almost level position. Thinking I was on a roll but not wanting to order any new parts, I switched the front springs. ALSO NO LUCK! Same lean. Anybody have any suggestions on this. Also, installed a heater motor and noticed something strange, (car has been rewired prev.) with out grounding the motor, have no low fan but have high. Ground the motor fan speed picks up. Was only one lead from motor and only one attachment prong aval. on back of switch how did I screw this one up?
Signed, looking of 61 driver parts
Clueless in Manhattan
