81Batmobile
I have an '81 with the 4 speed tranny. All good so far but my vette leans to the drivers side in the back. I just had all the body mounts replaced. All body panels and the t-tops line up nicely. From the ground to the bottom edge of the wheel well at the center of the hub on the rear is about 5/8" lower on the driver's side than the passenger's side. The rear spring was replaced about three years ago. My local corvette expert recommends I turn the rear spring around to see if the lean goes to the other side. Has anyone else dealt with this problem??
