toobroketoretire
Banned
I found my left rear tire was low again; about 10 psi. So I took it off and gave it a good visual check and found nothing. Then I submerged it into water and still found nothing. Hmm. I have seen tires like this in the past in which they needed weight on them to leak so this might be one of those. I had a tire slowly leaking when I restored this '71 and the leak was caused by severe rust pitting where the bead seats. I sandblasted the pitting down to bare metal then painted fiberglass resin onto the pitting to smooth it. It's possible this wheel is that wheel but it didn't show any signs of leaking so I am puzzled. It's about 90% worn out so I'll be replacing the rear tires in the late spring. Until then I'll just have to keep an eye on it and not let it get too low.
My vacuum reservoir is also leaking down during the night and I haven't found the cause of that either. Might be a headlight actuator beginning to leak. With these C3's it never ends.
