R
rcvivian
I just installed the second cam in my 396 and for the second time it eat one of my hydraulic lifters and colapsed three others...what am I doing wrong? I soaked the lifters in oil when I put in the first cam and lifters, the second time I installed them dry. Both times I pre-adjusted them rocker arms using the method in my Chiltons by following the instructions. The method described had me align the motor at TDC tighten certain valves, then crank the motor and tighten the rest. I tightened them until there was no lash (I did this by spining the pushrod with my fingers. Once I could no longer spin it, I stopped and then turned it another 1/2 turn). After doing this, I put the valve covers back on and ran it for about 10 minutes until I heard the lifters start knocking. I immediately turned the car off, took off the valve covers and found that some of the rocker arms were significantly loose. Having seen this before, I took off the intake and found the 3 colapsed valved, one that had been worn down significantly. I pulled the rest of the valves, and a couple were very hard to remove. I used all new parts.
Any ideas where I've gone wrong? Will the shavings require me to replace any of the lower bearings?
