V
verbanik
Should you hear any lifter tap at all in the Lt-1's? I have been looking at prior posts and answers and did not see anything about a slight noise. Oil pressure is good, and I believe the noise goes away after driving, I know the car has not been driven a lot over the last few years and since winter is setting in I won't be driving it much until the spring.
The lifters are mechanical (Solid) lifters and are adjustable correct? I will have to go back to a previos post to look up the procedure from the archive, any responce would be appreciated. I have also purchased the 72 Serv Manual and assembly maual, so I have been reviewing the instructions.
