light me up, please
  • Thread starter Thread starter gary b.
G
gary b.
electrical systems & me don't get along, so i hope you can help. all the outside lights work except the front marker lights ( under headlights). put in a new clear bulb,tried the lights & the clear bulb turned milkey white, & didn't work. also, when i turn on headlights, the turn signal indicators inside both light up . they both blink, left or right outside. when i open drivers door the inside lights don't work, but will work when passenger door is open. also, are all 4 tail lights suppose to light up ? only the 2 outboard one's do. i dont know how to read wiring diagrams, so i hope you can help. it's a 1978 vette. thanks very much! gary.
Front markers,are you sure you didn't get a pair of 6 volt bulbs by mistake.
Turn signels,bad ground in dash
Dome lights, door switch
Tail lights, only 2 outside lights light inner ones are the backup
barrier5
thank's for your help! the bulb's i used are 12 volt, any more ideas? where should i check for a bad ground? Thank's again barrier5! gary
I once had crazy tail lights. They woud be super dim at night and when I pressed on the brake pedal they would alternate back and forth. I found a ground wire that was broke. On my 80 it was in the rear drivers side above the muffler. The connection had rusted loose. I hope this helps. I almost lost my sanity on this one.
Main dash ground is just above the courtesy light on the drivers side
I believe the headlight ground is hooked to the back of the alt.though not sure,cold be why you toast those bulbs ? one other thing to try is to wiggle the plug on the back of the IP,but its a bear to get your hand up there,be prepraed to lose some skin
Thank's mmvette80 & barrier5, i'll try those things as soon as i can.
