Looking forward to 2003, future mods, new goals
69MyWay
Auburndale, Florida
1969 Killer Shark
Okay guys, I tend to find I have a better shot at accomplishing my goals when I announce them to all of you here. That way I can get your feedback, and some of you are good about holding me accountable to them.
So, looking ahead to 2003, we plan on making it a goal this time to drive Killer to the 50th celebration in June at the NCM, etc. What I learned from my trip to the NCM over Labor day is that....
There are some aweful rough roads between there and there (some fun twisties too). It is a good solid 11-13 hour run depending on other factors. I need plenty of storage/capacity for luggage, tools, chairs, shade tent, etc as those things come in handy. We need more gears. There is no way I will feel comfortable taching 3,000 RPM for 11 hours straight on the monster big block (sucking fuel and wearing out my a/c, power steering pump etc).
Since we nailed our overall "show" goals for the car the first time out, I am not that worried about the "wear and tear" on the car over the next year. In fact, some scratches and road chips will give it some more character.
Right now I have an issue with some fiberglass shrinkage in the upper front clip that happened after it sat in the sun over that labor day weekend for the first time. I will eventually have to block the nose back down and reshoot, but I am going to leave that alone in favor of reshooting after we get some road chips etc. to boot. This time, when I get to B.G., I just plan on driving and using the car vs. polish, shine, clean, prep, pimp, just to put on display. The only award I may get is for the dirtiest car there!
Here are the plans.
1. Richmond six speed
2. full dyno tweak and tune to have the engine fully maximized for round two with the Breathless Dyno (if it is there then)-thinking about a 250 hp shot of NOS just in case.
3. Construction and completion of a trailer to tow behind the car made out of the rear clip I have from a 79 Vette.
4. Consideration of a better brake system (at least I plan on looking for a more modern aluminum housing master cylinder) .
Right now we are set to caravan with TZracer in the sister project coupe to Killer (the 71 big block). That car is starting to make some real progress, and mostly because I have learned from mistakes on Killer to better direct the efforts on that machine.
So, what do you guys think? Can we do it? Should we do it? Are you going to hold me to it? Will you put up with me when I start whining and complaining with weeks to go before the trip and things start going wrong?
Here is the proposed trailer
Take a look at this, and please don't laugh yet.
My plan is to fit a light weight tubular frame under the C3 clip. I want to find a small seat that I can cover in vinyl that will flip up/down out of the way to run across the b-pillar section of the clip. I plan on putting a receiver tube in the main front structure of the trailer where a shade umbrella can pop and pin into place.
On the rear underside of the trailer I plan on setting it up to hold tools, spare oil, coolant, tape, parts, etc.
In the rear hatch, I want to set it up with a cooler, power source, radio, and room for a small outdoor grille, extra lawn chairs, etc.
On the front of the trailer I need a good quality stand so it will free stand off the car, and a way to chock/lock the rear wheels to keep it from moving once set in place.
My hopes would be to put a series of snaps around the entire open area to snap a vinyl cover over it for towing and storage.
Right now I am thinking there will be some weight transfer issues trying to keep 60% of the active weight in front of the rear axle.
Thoughts?
I like it. Particularly the colors you have penciled in. If anyone can do it you can.
What are the towing limitations of your vehicle? I know stock they are pretty low.
Bob
Bob
Good question. I really don't know the capacity. I will tell you that back in 1988 I actually towed my 69 camaro on a tow dolly behind my 74 stingray from Michigan to Florida with Zero problems. So that was a significant burden on the frame and drivetrain of the 74. However, the tow dolley does not create very much down force on the tongue. Then again, it had the full weight of the 69 camaro pushing and pulling on it through the mountains and the freaky fast and furious traffic through Hotlanta.
I plan on duplicating the trailer hitch we had built on the 74 on the 69 with the exception of using a descreat, neat, and clean receiver style hitch.
Chris,
If I'm not mistaken you don't have a spare tire carrier on Killer, and if your going to use the one on the trailer for tools your not going to have a spare tire for the trip.
I think a 68-69 rear-end for the trailer would look much better being towed behind Killer too.
Otherwise it sounds like a great plan to me.
Rick
btw, I didn't have a spare during the trip to BG:(
You won't have any weight on the hitch and the trailer will fishtail all over the place unless you get some weight up forward. I would mount a toolbox up towards the hitch end so to get some weight on the hitch. I would just mount a aluminium pickup truck bed box on the A frame up on the front end. You can then adjust the weight by adding tools to the box.
Putting the heavy stuff in the back of the trailer wouldn't be good.
Excellent plan
Having watched first hand your progress on Killer, I know you can make it work. You have already mentioned the 60% front weight bias to allow for good towing behavior. No need for spare with a couple of cans of fix-a-flat (who wants to change a tire on the side of the road????SUICIDE!!!). But, I wonder how many states would choke you down to 55 when towing a trailer? I don't know if I could deal with all the jokers flying by while putting down the interstate.
Otherwise, it sounds like redneck heaven! Beer cooler, shade, cool car.....WOOOO HOOOO!
