Hey Guys,
Thanks for all of the help with the warm start problem and fan issues. My mechanic was hesitant about some of your thoughts and suggestions but it turns out that you both were right. Anyway, I spent a lot of $$$$$$$$$$$$ to revive this awesome car so now some of the
-I hope-little things I hope to do myself.
Yesterday the low coolant light came on for the first time. So I stopped and checked the fluids in the radiator and the reservior. Both were good and the coolant looked like new.
First of all could this be a contaminated sensor or is it telling me that there is not enough coolant in the engine prior to thermostat opening? It did the same thing today and stayed on for a 50 mile trip. Coolant temps stayed at 175-177 on the highway and got up to 186 in town then back down to 177 on the highway. Return trip, no light.What do you think?
I'm thinking it is a bad sensor.
I plan to open the radiator cap tomorrw morning and let it idle until I see a drop in the radiator level. If no drop occurs after 195 degrees I assume the engine is filled to capacity. If it drops, I'll add some more coolant until the level in the radiator stabilizes to insure there is now low coolant.
Is there anything else I need to look for?
