Low Coolant Module Location
  • Thread starter Thread starter BobMaio
B
BobMaio
I have a 1986 Coupe and cannot locate the "Low Coolant Module". I have the service manual but it has not been a help. Can someone please point me in the right direction?? Thanks in advance.
Wrong Item
Thanks for responding, but you are referring to the sensor which is where you indicate. I need to locate the Low Coolant Module. It is probably under the dash somewhere. But I don't even know what it looks like.
Just what exactly does this low coolant module do? And why do you need to find it?
Just a few questions.
Craig
Module
It apparantly works in conjunction with the low coolant sensor that is in the radiator. I replaced the sensor and my "low coolant light" continues to light up even though the coolant level is good. According to the service manual I need to check the module. It must be some sort of relay used by the idiot light in the dash.
My low coolant light has been coming on lately. I have checked the level and alls well. It does this only part of the time. Maybe I need to check into this module. This is the first I have heard about it. Try private messaging the paul the c4c5specialist. He is great with these cars. He could probably tell you no problem.
Good luck
Craig
Oops, sorry. As I look in my manual, I see what you're asking about - and no, they don't really say where it is, do they? Have you traced that green level probe wire back from the radiator?
[RICHR]
I think I now know
I looked at some threads that showed up at the bottom of this page and I think I found the answer. It apparantly is behind the dash on the passenger side. I have everything off the dash at this point except that large pad. I guess it is coming off next. Thanks for your help.
