T
tom81
Can anyone tell me if the right hand (passenger side) lower control arm mount welded to the frame is the same as the left hand side were the mount fits the contour of the frame. Is there a left and right hand part or is one part used for both sides.
The problem I’m having is that the weld is failing on the right side and the control arm mount is separating from the frame and one side is almost gone.
It looks as if someone replaced it at one time and used a mount from the left side. Instead of the mount following the contour of the frame as on the left side the right side is in a very vertical position.
