J
jrizz1
I would like to lower the front end of my 2000 convertible. I found a "How To Tip" on another site and followed the instructions. It stated to adjust the bolt that attaches to the front leaf spring. Since the bolt has reversed threads, it said to "loosen" the bolt until the bushing bottoms out. I turned each side approximately 5 1/4 full turns. I drove the car around the block and checked the clearance between the top of the tire and the lip of the wheel well. I ended up with 2 1/4 on the drivers side and 2 1/2 on the passengers side. Should this gap be smaller, (lowered front end)? Do I need to adjust the passenger side more to equal it up? Will the car settle with some drive time or did I do the whole thing wrong? Thanks for the help.
