ls2 maf
danuge54
New member
Louisiana
02 maroon coupe
can an ls2 maf be installed on an ls1 and if so what has to happen to make it work,thanks Nuge
Well the answer is yes, kinda.
First the LS1 is 78mm and the the LS2 is 85mm in diameter. That means you're feeding a small diameter with a large on and air flow doesn't like that.
First you'll need an adapter:
Home » Shop » Connectors / Harnesses » Delphi / Packard » Adapters » GM Delphi / Packard - LS2 MAF to LS1, LT1, truck MAF harness adapter with IAT
I'd read this also:
ls1 to ls2 MAF - LS1GTO.com Forums
LS2 MAF sensor fit on LS1? - LS1GTO.com Forums
Do a search for LS2 MAF on LS1.
There is a lot more to it than you might believe. So invest the due diligence.
