URLUZN
- Joined
- Dec 29, 2008
- Messages
- 24
- Location
- Kingwood, Texas
- Corvette
- 2008 Victory Red ZO6, 2011 Silver Grandsport Coupe
My 08Z with 7000 miles, the oil pressure seems to fluctuate quite a bit. I have seen it as low as 26 psi at ~180f oil temperature at idle ~600 rpm. Engine warmed up good and a hot day. I know alot a factors come into play, ie ambient and engine temps, rpm, type of oil, etc. but just curious if others see pressures this low and if there is a concern? Most of the time @ 1500 to 2000rpm range it runs 46 to 50 psi. Higher rpms it will climb to 65+. Using factory Mobil 1.
