Hib Halverson
Last week I was in Michigan for a day of meetings with various engineers at the General Motors Powertrain Division. Two of the meetings were about GM's two new premium V6 engines, the LGW and the LGX. The third concerned the LS7 valve guide wear problem.
Present for the LS7 meeting on the afternoon of 24 March at GM Powertrain Headquarters in Pontiac, were: Jordan Lee, Chief Engineer and Program Manger for the Small-Block V8, John Rydzewski, Assistant Chief Engineer for Small-Block V8 Passenger Car Engines, Chris Cogan, Cylinder Head Design Release Engineer for the LT1, LT4 and LS7 and Yoon Lee, LS7 Design System Engineer. Also present was Tom Read, Director of Communications for GM Powertrain. In attendance for part of this meeting were representatives from GMPT's Inspection Department, from Zeiss U.S. and the GM entity which complies service information.
This meeting included a visit to the Inspection Department at GM Powertrain HQ where I observed a Coordinate Measuring Machine (CMM) session with the passenger side cylinder head which was removed from my engine in July of 2014 during a warranty replacement. A CMM captures measurements used to create an extremely precise, three-dimensional, digital model of an object, such as an LS7 head. The GMPT Inspection Department uses Zeiss "Prismo Navigator" CMMs which are accurate to two microns over a distance of 300-mm (.00008-in over one foot).
What I learned from LS7 Team at Powertrain will be incorporated into revisions to my series of LS7 articles which are posted here on the Corvette Action Center. These revisions will take some time to produce. There is no posting date for them at this time.
There are some open issues remaining after this meeting and they will be explored via a follow-up exchange of emails I will be having with Tom Read and the LS7 Team in the next week or so.
At this point, I can reveal some news items which came out of that meeting. I'll cover them briefly, here, and will expand upon them, later, in my revisions to the LS7 article series.
1) "Wiggle Testing" at best is inaccurate and in many cases is completely unreliable. Observing one of my heads being measured by one of GM's Zeiss CMMs proved to me conclusively that even the complicated and careful procedure I covered in my Wiggle Test article produces data which is inaccurate and inconsistent such that, unless the clearance measured is significantly greater than the Service Limit of .0037-in., the measurements are useless for determining if a head needs repair or replacement due to valve guide wear.
2) It is possible that heads which had Wiggle Test results of more than .0024 (intake) or .0026 (exhaust) but less than .007-in. stem-to-guide clearances had actual clearances below GM's .0037-in Service Limit, regardless of how the Wiggle Test was done. That possibility becomes greater as Wiggle Test measurements get closer to .0037-in. Once they approach .005-in., guides are likely in spec even though they Wiggle Test as bad.
3) Some, but not all, heads which failed "Wiggle Tests" and were repaired or replaced, either under warranty or not, actually did not have faulty valve guides and did not need replacement.
4) Wiggle Testing is "out" at GM. In early March, GM released to its dealers an update to ESI mandating a new procedure for measuring stem-to-guide clearance for warranty purposes in all high-performance engines. It requires a hole gauge to measure guides and a micrometer to measure valve stems or a valve guide bore gauge, such as a Sunnun P310, and must be done with the heads removed and disassembled.
5) The demise of Wiggle Testing as a way to determine if guides are worn was a result of the LS7 Engineering Team's review of the CAC's LS7 article series, three CMM inspections of the heads removed from my engine in July of 2014 along with the Team's need for more accurate information from the field about warranty replacements of LS7 heads. Additionally, the LS7 Team's review of selected content on the CAC and other forums may have influenced the decision.
6) According to Jordan Lee, the "machining error" stated on the CF by Chevrolet Customer Service in October of 2012, was a failure of the supplier to properly deploy statistical process controls and, as a result, the diameters of valve guides in some, but not all, heads made during that period were machined too large.
7) The "suspect period" for this machining error, previously stated by Chevrolet Customer Service to be 2008 to Feb 2011, is not correct. According to Chris Cogan, and confirmed by Jordan Lee, the suspect period was July, 2008 to March, 2009.
8) Only LS7 heads are manufactured by Linamar. LS9 cylinder heads were never manufactured by Linamar. LS9 heads were made in GM's engine plant in Silao, Mexico. I am partially responsible for that long-standing piece of misinformation. I apologize for any confusion it has caused.
9) The LS7 is currently manufactured at the Performance Build Center in Bowling Green and will remain so until the 5th Gen Camaro Z28 goes out of production.
I may post additional information concerning my 24 March visit to GM Powertrain as conditions warrant.
Thanks to the LS7 Engineering Team along with Tom Read, GMPT Director of Communications, for the time and resources they devoted to my visit with them in Michigan last week. I'd also like to thank the LS7 Team for their willingness to show me all the information they had available at the time of the meeting and their willingness to consider sharing additional information going forward. Finally, I appreciate the LS7 Team's interest in working with me to get as much information on LS7 valve guides as possible into the public domain.
Where's the dates? Thanks.
