S
SJ LT-4
I recently had some work done to my car. My plan was to have the heads ported, put in a LT-4 hot cam, port the intake manifold, and add a 58 mm throttle body. I already have a Borla exhaust system, Hooker short headers from Lingenfelter, forced air system through the font license plate, K&N air filter, Stainless pipe (where the cats once resided), centerforce clutch and 373 rear end.
Once the engine was opened up, I was called to the shop to look at the engine. The bearings were worn both in the crank shaft area and the cam area. This was a manufacturing defect. The engine only has 45000 miles on it. It was too late to take it to the dealer, sooo... I had the the engine machined true, odered new bearings, had the cylinders honed, put in new rings, and a new timing chain, new plugs & wires, while I was at it.
When finished, I was surprised at the dyno readings. My HP at the rear wheels was only 305, which nets out to be around 385 at the engine. The Torque at the engine is about 398. I was told I would have about 420 HP at the engine (Lingenfelter told me the same). The mechanic couldn't explain it. He said he performed the same work on an LT-1 and got about 420-425 Hp. He said the only difference was that the LT-1 had long headers vs. the shorties that I have. The other part is that the dyno ran my numbers assuming that I had a stock 342 rear end, instead of the 373 that I actually have. I don't know how much HP difference that would make, but I plan on getting the dyno readings done again, once I break in the engine. I appreciate any comments.
