trackitman
All -
Posted a video to youtube. Roller Rockers LT1 running - YouTube Just finished purchasing and installing correct length push rods. Set up is LT4 hotcam, advanced induction heads (ported), new valve job, Comp Cams roller rockers, lashed to zero plus 1/8th turn, running method. Oil pressure is good (60 psi cold, 40 psi engine temp).
My concern is there is very little oil pumping through the push rod into the top end of the roller rocker. When revving, you can see a small amount spitting out of the oil hole in the top of the roller rocker and hitting the adjustment nut. Is this adequate oiling for the roller tips, valve springs, and valve seals? Want to make sure before I button up everything and enjoy the rest of the summer.
Many thanks
Many thanks
