I am thinking about removing my smog pump and installing long tube headers om my 92 LT1. Has anyone done this? What do I need to know? Will removing the smog pump cause ECM issues? Any info will be appreciated.
Merle Hardy at Exotic Muscle usually has a special going for under 700 bonesWhere can you find Exotic Muscle headers? I have searched the internet but to no avail.
On a 92, the AIR system is not part of the car's on-board diagnostics. If you remove the pump, there will be no "ECM issues".
Coated.. Absolutely!!! No debate. Your plastic underhood parts will appreciate it, first600 uncoated or 750 coated.
I did. Besides the cat needs the air and may avoid clogging it up, in time.I would leave it hooked up. It takes up 0 hp and helps car run better.
