oledocclock
I recently purchased an LT4 with 14,400 actual miles showing on the odometer. I also have documentation showing that 14,400 is the true mileage. s The owner advised that sometimes when shifting into third gear the shift would be difficult and the gears would grind. I did a thorough test drive and had no problems with the up shift or down shift to third gear. I purchased the vehicle and have found that about sixty percent of the time I will have difficulty going into third gear and the gears will grind. Does anyone have an idea as to what is causing this problem? Do you have any advice on how to fix the problem?
