R
Richard Cooper
I am still unable to find the problem with my M/C solenoid. When I disconnect the plug from the solenoid on the carb and run power from the battery directly to the solenoid ( the part that is actually in the carb) I can make it "click" every time I touch the ground wire to ground. But, when I hook it up the way it should be the solenoid does not work and the car runs VERY rich. I have replaced the computer two times and just replaced the PROM and still, no good.
I am running so rich that when I change my oil it really smells like gas. I seem to have power at the plug end too, but nothing happens when I plug them together. Its like it is not switching the power on/off like it is supposed to do. Does anyone have any ideas that I could try? Thanks in advance.
