JOHNNYB
HI I WAS JUST WONDERING IF ANYONE HAS EVER HERD OF A MASTER CYLINDER BINDING UP FROM DIRT ENTERING BECAUSE OF DIRT IN THE CUPS AND SIMULATING HARD BRAKES LIKE A BAD BOOSTER?
THANX
THANX
THANX
Its entirely possible..
The m/c is just a single stroke hyd pump that has a very close tolerence plunger/piston cup to cyl wall difference. Its tight to make sure the fluid moves instead of slipping past. A system that slips is unsafe and brakes need to work everytime..not most of the time.
I've had the pedal go completely soft to the floor with zero braking, then return to normal because of dirt & trash in the M/C holding valves open.
Something else to consider, caliper pistons binding or seizing from dirt. The normal wear of a complicated ABS system with the pumps and added seals causes crud to accumalate and contaminate the fluid. If your fluid is getting dirty, it needs to be flushed before the dirt destroys the ABS as well as the m/c and everything else. Certain C4 yrs have almost no ABS parts available, so take care of the one you have..
AND IM DEF GOING TO FLUSH IT ASAP BUT DO YOU THINK I SHOULD HAVE THE MASTER CYLINDER REBUILT TOO ? A BAD POWER BOOSTER WOULD HISS RITE ?HEY THANX FOR THE ADVICE I DIDNT REALIZE THAT THE ABS PARTS WHERE THAT SCARCEAND IM DEF GOING TO FLUSH IT ASAP BUT DO YOU THINK I SHOULD HAVE THE MASTER CYLINDER REBUILT TOO ? A BAD POWER BOOSTER WOULD HISS RITE ?
