M S D Coil
PLRX
So CAL
Is the MSD Blaster GM Dual Connector Coil, PN 8226 safe to use in my 95 LT1? Is this a bolt on replacement? I don't want to start a fire
RU having a problem with your coil?
If not how much power do you think you need to fire your plugs? The HEI has plenty for a non-huffed sub 7k rpm motor.
Maybe a visit to the ignition experts at OC Speed will help you decide.
