Viet Nam Vett
- Joined
- May 28, 2004
- Messages
- 2,410
- Location
- Egg Harbor Township NJ
- Corvette
- 65 BB 502 Cp /MSD ATOMIC EFI/ 2009-HUMMER H2
magicv8 said:If you run the switch wire to the neutral safety switch connector on the harness above the wiper motor, you don't need to cut the wiring and the switch can be disabled by restoring the default plug connection.I forgot about people who leave their manual transmission cars in gear.
You guys are right, this is a fender saving option.
PS: Sure is boring having to put line breaks in these posts to get blank lines inserted.
"Danger Will Robinson.." If you do extend wires from your neutral saftey switch at the fire wall ...you must be careful. I tried this once thinking I would install a kill switch and locate it some where under the dash area on the driver side.
I used 12 Gauge wire. When I hit the key to start.. the wires started to get warm and the motor would not turn over. REASON...to much resistance for that wire length run. I would have probably had to use 10 gauge or 8 gauge as it was about a six foot run ...3 ft down one wire and 3 feet back up the other wire.
Not sure of the wire length from the connector at the fire wall to the switch on the auto tranny and or the gauge wire used in the stock set up.
Anyone care to comment??...
