S
steve1ph
still need help with two problems im having. just got thru putting on the super ram intake 58mm tb and 36# injectors. now the car will idle normally for a few or untill it gets warm i guess then the idle will jump to 3k and stay there. also now the car is running very very rich. i replaced the o2 sensor and the pvc valve. still the same. also while the car is running iv sprayed ( carb cleaner) around all the intake, vacume lines, tb any where there could be a leak and did not get the car to rev up, hence no leaks. as well there is no check engine light on at the dash. puzzeling. all advice will be tryed. also want to let every body who reads this that iv done some business with another forum member by the name of MAD-MIC and want to let everybody know that he is trustworthy as well as myself. hey mad-mic handshake to you, that wasnt possible in person..........thanks
