Manual 6 Speed Problem
willmike
Charleston, SC
1994 Red Coupe
Has anyone had any experience with a manual 6 speed that when you shift into any gear, the car will shift, clutch seems to release ok, but the car starts to buck. I did notice that I have some leakage on the deck of my garage, but could this be a low transmission fluid problem?;shrug I have not changed the fluid or checked it since I bought this car in 2004. I have a 1994 coupe.
Any input would be greatly appreciated..
V/r
Mike W
V/r
Mike W
Check the fluid in the clutch master,if it's low you may have a slave cylinder going bad!!:upthumbs
Had the same problem with my 94 convertible. Junk said it could be the clutch slave in your case. In my case, the clutch master cyclinder failed - had to replace. Everything was fine after that.
Barrett
Barrett
Actually it could be either, Or Both!!! But in light I'd think it's the Slave by something leaking on the floor!!! Master usually leaks under the dash, in or under your Carpet!!:upthumbs
