jamison
I have a 1990 with the 2 fan relays located on the driver side radiator shroud. i want to wire up a manual switch to turn both fans on and off with out having to turn on the ignition key this way when i take the car to the track i can have it cool down between runs. but i also need it to have the fan temperature switch working properly when just cruising the town. i have seen kits online from mid america, but im not sure if they work with the ignition off. plus i have already bought a switch and have plenty of wire. i just don't know how to wire it up. that where i could use your guises help.
thanks jamison
thanks jamison
but the relay markings don't lie. Mine has red wire to one of the contact terminals and to one side of the coil.The other side of the contact goes to the fan, should be a fairly heavy wire. If you can see the top of the relay there is a pictorial diagram on it.
