M
Midwest Vette
I think I have a couple of problems with my manual a/c. #1 a/c is warmer on the drivers side.
#2 a/c seems to blow cooler at low rpm's. could this be a possible vacuum problem ? I had the leaking battery problem & repaired the hvac vacuum lines, I get air out of the right places since the repair. Could it be a bad check valve on the vacuum cannister or the cannister it self ?
I have a 98 coupe.
I have a 98 coupe.
