VAroute66
Was putting in the drive shaft and when trying to line up, tried and could not turn rear wheel in neutral. Removed shaft. DNE/Richmond 5 speed goes into all gears (checked ratios), but will not go into neutral. Ratio in neutral same as first gear. All linkages go to correct positions in all gears. Everything is new. Anybody ever hear of this? Thanks in advance.
V/R
Dan
V/R
Dan
