not the first person to sugest that, would of been great if i did it $7000.00 ago
does anyone know a site were i can get factory service manual
do a search here for FSM and there is a link for CD versions or books.
EBay has books for sale, used or new. 75 to $150 depends on which.
Not trying to be adversarial, but I have to believe that this is not impossible. Its a machine. Thats all. If you understand the machine then you understand the problems it can have.
Someone has overlooked or neglected to do something simple. If your techs are not trained in GM or Corvette technology then they are NOT qualified. Corvette utilizes systems that no other car used in the 80s when the C4 matured. Only a top shelf Caddy had similar eng mangt systems. Todays mechanics will tend to approach a C4 and treat it like it was a carbed 77 Camero and try to adjust things that were never meant to be touched. They disregard sensors and their value to the system. This engine has 4 different temp sensors...actually 5 if you count air temp sensors as well as coolant for the engine. MORE for cabin and outside air. Knowing which does what and for which system is crutial. Some are switches. Some are variable resistance value sensors. Dirty connections on the eng coolant temp sensor can cause all form of hell and misfire. A stuck EGR time/temp switch will make the eng burp and backfire. A harness thats allowing cross-signals will defeat all sensor inputs. All, easy to track down and figure out IF you have the FSM and some patience.
I just do not accept the fact that experienced mechanics have thrown that much money at that motor and it still coughs and won;t run. That tells me they're GUESSING. Like I said, I'm not trying to offend, I'm trying to get you pointed in the right direction so you can enjoy the finest car made in this country and one of the finest in the world. It should never be a headache and a regretable choice.
Its pretty basic...it gets fuel and it needs air. The air is metered and fuel is adjusted accordingly. The prom dictates the operating parameters and the prom IS the tune, not the old school adjustment of a few things. getting the timing in the 'window' allows the ECM to do the rest...it'll run as long as its close.
This could easily be the dist being off by 1 tooth. Happens everyday. Wires crossed. Wires pinched inside the dist cap.
If its still showing MAF codes then there is a problem with the MAF system. Wiring harness, relays, plugs and especially grounds. Your new FSM will tell you where the 20 or so ground contacts on the frame live. There are 5 that are CRITICAL by the oil filter.
Somebody missed something. its not witchcraft. These things are predicatble but only when good, factual info is available. Try this or adjust that don;t work. Whats to adjust? the ECM does that. The correct sensors and the correct data must be available to the ECM or you end up with a mess like this. HAs anyone put it on a scan to see what the ECM is seeing?
If I were there I';d do it for you because I'm positive that its nothing unusual. It never is. Fuses, links, bad harness wire...bad weatherpak connectors. All can be traced if you understand the system. being a good mechanic is fine for hub bearings (which you have'nt explored yet) or changing u-joints but when it comes to the engine performance, it takes someone experienced with C4 electronics to figure it out.
Get your FSM and study the basics, then start with the flow charts and follow them exactly. There is NOTHING that is not covered in the GM FSM.
Try to find an older copy because the newer book on the electrical is in B/W I'm told. The older books are color exactly as the harness is. Much easier to follow.
Good luck
