R
RMJones
I just purchased a 1992 Dark Red Convertible with white leather and top. It is a 6 speed with only 18K one owner documented miles and has never seen rain. The wheels tubs look like new! I ran a Carfax (for what that is worth) and my buddy ran an AutoCheck with no accidents or major issues found. I have the window sticker and all service documentation. I want to take it to Bloomington next year and get it judged but how do I tell if all the numbers (VIN, Engine, Tranny) match up? Will they look at that?
Also, my car has a new water pump, coolant and thermostat. With the AC on it runs at about 195 degrees. Turn the AC off and it climbs to 226 until the fans come on by itself. Is this normal to be this hot?
My car runs great (I do get an annoying intermittant Service ASR light from time to time) but the car has done alot of sitting. The more I drive it the less I seem to get the light. No other lights. Any thoughts?
As far as I can tell the only fluid that has never been replaced is the rear end. Should I do it with only 18K miles?
How bad is this Optispark thing? Mine starts the second you hit the key cold and hot and runs super strong through all RPM ranges. Should I be worried about it failing due to age? I have the original plugs and wires!
Any help would be greatly appreciated. I know I am asking alot of questions! Thank you in advance!
