alson81
just bought 81 vette. where exactly would i find engine #s to see if it is the original motor in this car
On the passenger side of the engine, there is a pad on the block by the front end of the head. Should be two sets of numbers set there. One set of numbers will correspond with the last digits of your VIN tag numbers, the second set will be the engine build date and engine code. The VIN numbers typically will be smaller than the engine code numbers/letters.
