Maximum ZR1/C4 front negative camber?
jefmd
Midwest
1989 Coupe
What is the maximum ZR1/C4 front negative camber setting? The 1990 ZR1 included a ZR1 Driver's Manual. In the Off-Road Driving section alignment settings are discussed as follows: "Standard ZR1 alignment settings are suitable for street or track. However, racetrack performance can be improved by a change to the following settings: Front Caster: +5 Front Camber: -2 Front Toe-in: 10 ft. Rear Camber: -1.25 Rear Toe-in: 25 feet. These are baseline settings for racetrack use...Always change back to standard ZR1 alignment settings for public road use." They do not describe how that much front negative camber is obtained. The rest of the settings are possible. I do not know any ZR1/C4 drivers who can get much more than Front Camber: -1 without doing major work or using non-factory parts. Is Front Camber: -2 possible with factory adjustments? If so, how is it accomplished? Is this procedure listed in a GM service manual as a range of suspension and/or alignment adjustment? (1989 Corvette with Front Camber: -0.8 and hoping for more.) Thanks
