This information was printed in a 16 page 3-part series of Corvette Quarterly in the Summer, Fall, and Winter issues of 1990. The editor’s note indicated it was provided as a separate Driver’s Manual for 1990 ZR1 owners in addition to the regular Owner’s Manual and was relevant to both L98 and ZR1 owners. The Winter 1990 issue included the information about off-road driving and alignment suggestions.
Yes, I agree the toe-in values do not make sense, but I suspect is incomplete data to make adjustments at the track. There is reference in another thread to an alignment system designed by McPherson (of McPherson strut fame), which shows 10 ft and 25 ft reference points. I use 1/8 in toe-out in front and 1/8 toe-in in back.
I have the base suspension and resultant ride-height. I use single adjustable Koni shocks all around. Front Castor is about +5 both sides. To get Front camber of –0.8 all the removable shims were removed. I have asked my mechanic if the inside upper control arm round bushings could be removed (or replace the larger front with the smaller back bushing and leave the back bushing out) to gain additional negative camber while maintaining castor.
This appears to me a very reasonable way to gain additional negative camber while maintaining easy return to stock settings, using stock parts, and adjustability. My mechanic is hesitant to do this, as he has no information as to whether the suspension was designed for the additional adjustability.
My 1989 coupe has 51,000 miles, is garaged, is used weekends regularly spring thru fall, had new lower ball joints last spring, and new hubs, rotors and brakes 1 ½ years ago. Except for a Borla exhaust the car is otherwise stock. The car is maintained regularly using stock parts or equivalent. I enjoy autocrossing regularly.
Tire temperatures do indicate a need for more camber if possible. This has been more of a problem the last several years with Hoosier and Kuhmo tires. It was not a problem with Yokohama A008 or BFG Comp T/A R1 tires. The current Hoosier, Kuhmo, and Yokohama tire information all suggest more negative camber is helpful. Currently I use air pressure, shock settings, and regular tire rotation to try to compensate. More negative camber would also help achieve better tire wear.
I have owned this Corvette since Feb 1990, and continue to be impressed with its durability, reliability, serviceability, and performance. Thank you for your help.
